after fixing my Itr swap problems..now I have wiring problems ..PLEASE HELP!
well....thanks to you guys for your help and fixing my motor swap problems.
After that..I now have more problems
I just got the car painted inside and out and to do so..i stripped my car inside and out. Anyhow...
when I turn the key to the on position...usually ( on a normal basis..you should see the battery light on the gauge cluster come on and hear the fuel pump turn on) in this case...it doesnt. Sometimes it does...then the car will fire right up. THen I turn the car off...and same problems occur.
I hear buzzing and ticking sounds coming from the fuse box area in the interior
Also..weird weird weird syptoms like...ill turn on the wipers and the gauge cluster turn signals green lights come on and then the e brake light comes on.
I turn on the heater and the i hear a loud buzzing.
The fuel gauge on the gauge cluster goes beyond the full point and I know I dont have a full tank.
All in all..when it "spontaneously" cranks over..the motor runs PERFECT ..thanks to you guys
What could this be?? Problem after problem is so frustrating..but its good to know I have my mentours here on h-t \
Thanks for any help you can help me with
****UPDATE****
now when it does turn over...after about 45 sec. to a min. its starts making the motor miss..like its runnin on three cyl.
Im wondering if its a ground issue. I did strip the car completly for paint and bodywork. Also...when I turn on the heater or blower...it start ticking in the fuse box in the engine bay from the realy for the heater blower.
PLEASE HELP..IM DESPERATE AT THIS POINT
Modified by YFZ350 at 11:50 PM 8/3/2004
****UPDATE****
Moderator
Re: after fixing my Itr swap problems..now I have wiring problems ..PLEASE HELP! (YFZ350)
you have wiring issues.....did you hook up all the wires?? if so go back over...you have something hooked up wrong!
Re: after fixing my Itr swap problems..now I have wiring problems ..PLEASE HELP! (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">you have wiring issues.....did you hook up all the wires?? if so go back over...you have something hooked up wrong!</TD></TR></TABLE>this is my first swap. I dont even know where to start. You think I should just take to a wiring specialist?
I don't know check the relays, it usually the case with fuel pump priming problems. I don't know about anything else.
Former Moderator
Is the ground for the engine hooked up on the thermostat housing?
Re: after fixing my Itr swap problems..now I have wiring problems ..PLEASE HELP! (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Is the ground for the engine hooked up on the thermostat housing?</TD></TR></TABLE>yep sure is. Only ground not hoooked up on the motor (which imma do today is the one from the rad. support to the valve cover.
Rotten_ef
07-25-2018 12:35 PM
Stunna MIKE
02-23-2012 06:50 PM
