idle air control valve
Old 07-28-2004, 06:38 AM
geldingmakr's Avatar
Default idle air control valve
what should it act like with the idle air control valve wiring harness un hooked?
i've been having an over heating problem, and a crazy idle that rev's to 2200 and back down to 1000... and back and forth...
last night i changed the thermostat... and bled the air out of the system...
it still idled crazy.... i removed the air filter intake, and when i plug off the side hole in the TB with my finger, it idles fine....
i unplugged the harness to the idle speed control valve... and the idle got a lot lower and it stopped rev'ing up and down... but it still idles at 1300....and lopes to 1400>back to 1300>1400>1300
what should it act like with this wiring harness un hooked?
geldingmakr is offline
Old 07-28-2004, 06:41 AM
Electrician
Deemeetree's Avatar
You'd proabably have erratic idling. Have you tried adjusting your Idle Screw to see if it would go down to 700-800 RPM range?
Deemeetree is offline
Old 07-28-2004, 06:48 AM
Default Re: (Dimi)
yes... i have screwed it all the way in with no luck... and tried screwing it out... and it only got higher...
Old 07-28-2004, 06:51 AM
murmur9's Avatar
Default Re: (geldingmakr)
Did you just hook this engine up or did it just start doing this?
murmur9 is offline
Old 07-28-2004, 08:06 AM
Default Re: (murmur9)
it just started.... actually about 3 weeks ago... after i changed plugs and
cleaned the TB with some carb adn choke cleaner...
for about 2 weeks it started idling fast.. like 2000... then about a week ago
it began the reving up to 2200, and then falling to 800-1000... and reving to 2200 and falling.... and so on...
Old 07-29-2004, 03:09 AM
well i just realized last night... that my engine light does not come on when i first start the car to let me know it is working... so i very well could be throwing a cel...
is there a way to pull the cel codes with out having the dash light operating?
Old 07-29-2004, 04:04 AM
mct121's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geldingmakr &raquo;</TD></TR><TR><TD CLASS="quote">is there a way to pull the cel codes with out having the dash light operating?</TD></TR></TABLE>
I am thinking about buying another car and I don't want to get shafted by someone pulling a bulb to hide the CEL. I was just thinking about this same question the other day.
bump for my curiosity.
mct121 is offline
Old 07-29-2004, 05:40 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: (mct121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mct121 &raquo;</TD></TR><TR><TD CLASS="quote">
I am thinking about buying another car and I don't want to get shafted by someone pulling a bulb to hide the CEL. I was just thinking about this same question the other day.</TD></TR></TABLE>
wow, i never thought of that one.
TouringAccord is offline
Old 08-04-2004, 09:11 AM
look at this picture... and let me know if it helps diagnose my idling problem
05-13-2019 10:43 AM
troyport
Classic Hondas
05-28-2009 09:06 AM
l8tnitcivic
06-05-2007 02:37 PM
rockofcali
04-05-2007 02:50 PM
jdmcrx_echelon
08-29-2006 12:33 AM
Quick Reply: idle air control valve
  • Ask a Question
Question Title:
Description:
