(help) what things to mount n wire ctr mirrors
i just got some power folding ctr mirrors. what do i need to make them work on a 97 hatch? as far as wiring n mounting them ..thanks for any help
Re: (help) what things to mount n wire ctr mirrors (silver ek)
it should mount the same way as a Si would...did you get the wiring when you bought the mirrors? and a control module?
i have the non powered ones...they just use 3 screws, 8mm or 10mm i forgot and it should come with all the wires if it just power mirrors? or power folding? if it power folding then you need the control unit for it...and for power mirrors i think the Si 99-00 will work...like i said im not 100% sure
Re: (help) what things to mount n wire ctr mirrors (JDMFreak)
i mounted them not a problem..i need help on the wiring part. i have the switch n the relay direct from a ctr but how do i wire it on to a cx u know that cx does have any power to the mirrors..thanks for any help
Location: Good luck to this industry, you're gonna need it.
If you didn't UNPLUG anything off of your stock mirrors, then you DO NOT have power mirrors. If that's the case, you need to find a wiring diagram from your local dealership or whatever and run all of the wires inside the car under the fenders...YES IT'S a bitch. Then you need the relay pack and the switch for it. If you don't have those the mirros won't work. Buy those parts. If you do have those parts then wire away... OR FIND SOMEONE WHO KNOWS HOW!!!
-Chris
-Chris
Re: (help) what things to mount n wire ctr mirrors (EK_TNR)
i have the switch n the relay just need help on wiring. i know i don't have power mirrors no ek comes with power mirror (usdm) need more help
slkleltlclh
12-28-2006 04:23 PM
blouto
09-28-2005 10:31 AM
BigMoneyP
03-29-2005 08:14 PM
FourthGenHatch
10
05-28-2004 04:43 PM
