B16A but what year?
B16A but what year?
ok I just got my JDM B16A and Im trying to figure out what year it is?
is there any ways to tell them apart....physical distinctions or maybe the serial number under the stamp could tell me?
The stamp Reads
B16A
1021094
Modified by knowles_101 at 6:27 PM 8/28/2004
The stamp Reads
B16A
1021094
Re: B16A but what year? (knowles_101)
on the head, at the top left side right near the exhaust manifold there is a little circle with 2 numbers in it like this 9|3 or 9|5 or whatever year the engine is. Also, does it have the MAP sensor as part of the throttle body or is it external, by external i mean is there a vacuum hose going from the t-body to the map sensor located somewhere on or near the firewall?
You can't actually see the circle with the numbers in it in this picture but it will give you an idea of where to look. Look at the top right of the picture. Oh and if you still have the exhaust manifold heat shield on you prolly won't be able to see the numbers. Hope this helps
any b sweries tranny will fit
but if you have a hydro clutch you will need a hydro tranny
if it is a cable clutch you will need acable tranny
first gen is cable and second gen is hydro, you have cable. you will need a hydro tranny and a cable---->hydro conversion kit
Jake92eg
15
09-19-2007 05:57 PM
-Whitey-
11
01-27-2003 12:36 PM
