Aircraft remover harm??
i was wondering ig that aircraft remover will harm my rubber tires, cause i painted them graphite and want to amke them aluminum like they were. thanks
Re: Aircraft remover harm?? (Revolver)
well "aircraft remover" is a solvent that takes paint off most people here on the forums know what that is, i was wondering if it would eat through my tires, apperntly it doesnt take much to confuse you....
Re: Aircraft remover harm?? (Soccerking3000)
OK, well thanks for the answer, however i'm not exactly new and havent heard that mentioned ever so maybe......you're an idiot?
please leave my thread you're not helping nor adding any additional information thank you i dont need to get into an arguement with you so just leave
I came to ask you a question and you gave me a hard time. That puts you on a level with idiot noobs. I said I was lost because I didnt know what you were talking about and it seemed that you were incapable of puting your sentence together properly. Especially for someone who didnt know what you were talking about. You suck at life
How about this:
For whatever reason you may have had to spray your tires.....I'm assuming you were painting your rims with the tires on. You can also try brake cleaner and a brush to get it off. It also won't harm your tires.
Are you spraying it on the rim or tire? If you just want to remove paint on the rim, cover the tire to avoid damaging it. I don't know if it would or not but that **** is really acidic or something. It could eat through your hand!
thank you for your input ,i didnt paint my tires though i am worried about overspray from the aircraft remover, it is in aerosol form and i dont want any getting on the tires, the problem is the paint goes all the way around the lip cause i painted the rims without tires on them.
If removing your tires isnt an option, then I would just wrap something around the tires as best you could. Sonds like this stuff could do some damage to rubber.
ya it is pretty potent stuff, it'll remove any paint, spray leave for 10 minutes and it will spray off with a hose, but thank you for your advice
edit: i painted my tires W/O the tires on, the wheels are aluminum so i just want to strip the paint off w/o damaging the tires but the paint goes below the tire i don t care baout whats under the tire but i want it to all be aluminum again
i've used this stuff alot for all sorts of purposes, even cleaning stickers off paint.
when using try to avoid putting it on the wheel/tire. this **** is nasty-mean in large amounts or when it sits on rubber/plastic/paint. what you should do is spray it on a cloth and rub it on the tire like you would use paint thinner on drying paint. if theres alot on the tire, spray it lightly, then wipe it with the aircraft-dampned rag. when you get it all off wash it or spray it with a hose, if any residue sits it can potentially cause damage.
the key is to not let it sit. if it sits on anything it'll eat thru it (if petro based) or take every memory of paint off.
EDIT: DON'T LET IT SIT FOR 10 MIN! i've lost a few rad hoses and tires that way, it should just take seconds. just spray, and wipe
Re: Aircraft remover harm?? (MonkeyMagic)
wear gloves btw, it will burn your fingers and knuckles badly b4 you realise it even start to hurt. It just tingles a lil bit and then all of a sudden your skin is coming off, lol
Re: Aircraft remover harm?? (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 »</TD></TR><TR><TD CLASS="quote">wear gloves btw, it will burn your fingers and knuckles badly b4 you realise it even start to hurt. It just tingles a lil bit and then all of a sudden your skin is coming off, lol</TD></TR></TABLE>
You're not kidding. God damn that stuff is harsh!
Scot
10
02-26-2008 07:24 PM
