Alternator Pulley Install **
Old 08-28-2004, 04:11 PM
Draggin99Si's Avatar
Default Alternator Pulley Install **
How easy is it to install an alternator pulley? I know it's in a cramped *** space. That's why I let a mechanic install my AEM alternator pulley a few years ago.
Now I need to put the OEM alternator pulley back on and want to do it myself. I was reading over the instructions that came with the AEM alternator pulley, and it said basically to remove the upper and lower alternator brackets, then remove the alternator from the car, then remove pulley from alternator.
Is it necessary to remove the alternator from the car, or can I just access the pulley lock nut without removing the alternator (is there enough room?)
Old 08-28-2004, 06:02 PM
nocturnaldragon's Avatar
Default Re: Alternator Pulley Install ** (Draggin99Si)
U may also be able to just undo the lower bolt, and flip the thing up enough to get clearance, But as easy as it is to pull the alternator out and put back in, id say take it off and do it on the work bench just make sure you make sure its all tight and lock-tited when you put it back togther
Suprdave
10-03-2004 02:45 PM
Speedra500
05-09-2004 09:57 PM
jasonb
08-05-2003 07:15 PM
ziggity
03-14-2003 12:11 PM
CKim
03-04-2002 07:03 PM
Quick Reply: Alternator Pulley Install **
