Brake Fluid Leak - Please help!
I started this in the tech section with no responses, so I thought I would try here. Please help!
https://honda-tech.com/zerothread?id=972628
Thanks
Thanks
Re: Brake Fluid Leak - Please help! (Rhythm)
Re: (BatuKing)
Thanks for your help BatuKing...
Here's a pic. The yellow line points to the hole the rubber piece fits into. If anyone has an old prop valve that doesn't work, please let me know if I can get this piece.
Thanks
Thanks
Re: (Rhythm)
I ended up buying a 4040 prop valve. My problem now is that the brackets are different. The bolts that hold the bracket to the prop valve have torx heads, but there is a small bump in the middle that keeps a regualr torx head from removing the bolt. Is there a special tool that I need to get these off? Please help if you can.
Thanks
Thanks
jdm inc
10-30-2010 11:41 PM
fv8s
09-30-2010 10:13 AM
