Rear disc conversion...will 1990 integra work?
Hey guys, I have a 94 civic coupe si and it has drum brakes in the rear.
I have a friend that is parting out his 1990 acura integra and it has rear discs.
Would I be able to use those rear brakes off the integra and set it up on my civic??
I tried searching but couldn't find anything for 1990 integra brakes
thanks
thanks
Re: Rear disc conversion...will 1990 integra work? (hatchi)
is this a hard swap???
I've never done a swap like this.
So all I do is bolt up the whole rear suspension?
Do I have to run brake lines and stuff like that?
thanks again
Edit:
also is there any difference between the EG rear shocks and the DA rear shocks???
thanks again
Edit:
cute little bastard
Re: Rear disc conversion...will 1990 integra work? (Mr.RHTuner)
Take everything you can off the integra: Trailing arm, control arms, rotors, calipers, e-brake cables (im 99% positive you cant use your own). Make sure you have all the bolts and nuts for everything. Bolts for calipers, pins for the e-brake cables. The guy I bought if off in NJ named Sal ripped me off and that **** was such a headache. Also if you're looking for better braking power, take the brake booster and master cylinder (if they are 15/16) and 40/40 proportioning valve from the teg too. After that stainless steel lines. Am I missing anything?
u sure its an si, cuz si's only came in a hatchback model in that generation, and also the si comes standard with four wheel disk....
Re: Rear disc conversion...will 1990 integra work? (s.patel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s.patel »</TD></TR><TR><TD CLASS="quote">u sure its an si, cuz si's only came in a hatchback model in that generation, and also the si comes standard with four wheel disk.... </TD></TR></TABLE>
Yes I have an Si....CDN model..so I belive it's EX in the us.
I have all the Si goodies and I know for a fact because of papers.
memoryFAB.com representative
i didn't know that a 90 integra rear discs would work with an EG???!!?? can someone confirm this please?
Re: Rear disc conversion...will 1990 integra work? (spock_rocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker »</TD></TR><TR><TD CLASS="quote">i didn't know that a 90 integra rear discs would work with an EG???!!?? can someone confirm this please?</TD></TR></TABLE>
I know a guy that has them
I had them bolted on my ek
Damn i thought the 90-93 integra rear disc wouldnt work...I had a complete car in my backyard that i could have ripped it off and put on my civic...But its junked now...Boo for me not knowing
Re: Rear disc conversion...will 1990 integra work? (LudeSH)
ok...well I came across 94+ GS-R conversion. If the guy won't take what I offer I'll be getting the 90' integra disk conversion
dammit I hope this works
GserpleaSR
08-30-2006 06:11 PM
