will a comptech type r header fit 00 si?
as stated above will a comptech teggy type r 4-2-1 header fit an 00 si? if so any fabrication i need to do for it to fit correctly? or will it just bolt on no prob/
All Motor Mentor
1 Post
Re: (murmur9)
It will fit but it will hang a little lower on a B16 motor reducing ground clearance. You'll probably also have to chance your cat to one with a larger flange to fit the header.
Darth ModerVader
Re: will a comptech type r header fit 00 si? (Tommytom83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tommytom83 »</TD></TR><TR><TD CLASS="quote">as stated above will a comptech teggy type r 4-2-1 header fit an 00 si? if so any fabrication i need to do for it to fit correctly? or will it just bolt on no prob/</TD></TR></TABLE>
The header will bolt to the head just fine, and the header's length will also be perfect. The only problem is the angle of the flange at the collector. The ITR flange is rotated at a different angle than the Si, so the cat won't bolt-up. If you don't want to modify your stock cat, an ITR, LS, or '00-'01 GS-R cat will work. This information is 100% accurate, as I've installed an ITR header on an Si in the past.
Re: will a comptech type r header fit 00 si? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
The header will bolt to the head just fine, and the header's length will also be perfect. The only problem is the angle of the flange at the collector. The ITR flange is rotated at a different angle than the Si, so the cat won't bolt-up. If you don't want to modify your stock cat, an ITR, LS, or '00-'01 GS-R cat will work. This information is 100% accurate, as I've installed an ITR header on an Si in the past. </TD></TR></TABLE>
Good work! I was just about to say that!
well i was thinkn bout replacing my cat with a carsound one, which one should i get to make this setup work?
SPORT INJECTION
09-08-2002 12:30 AM
