question about map sensor
Old Aug 27, 2004 | 09:33 AM
Btothe3rdDegree's Avatar
Default question about map sensor
well my setup is almost complete and i am going to run uberdata, but i am not going to have a o2 sensor, just my wideband, so i will be running in closed loop mode, my question is, i thought in closed loop mode your ecu ignores the sensors, so wouldn't it ignore the map sensor also? so couldn't i boost s much as i want in closed loop mode?
thanks guys
Old Aug 27, 2004 | 09:01 PM
Default Re: question about map sensor (Btothe3rdDegree)
ttt
Old Aug 28, 2004 | 08:37 AM
Octoman's Avatar
Closed loop looks at the O2 sensor to make corrections to the amount of fuel injected.
Open loop ignores the O2 sensor for sure, I am sure that it use the TPS, MAP and ECT sensors to determine fuel and timing from a predertmined fuel/timing map. Just out of curiosity, why will you not be using open loop?
I believe that there are wideband O2 sensors that can mimick the signal needed for the ECU.
Old Aug 28, 2004 | 05:35 PM
Default Re: question about map sensor (Octoman)
i wont have a o2 sensor, just a wideband
Old Aug 28, 2004 | 05:46 PM
Jago's Avatar
it will still look at all other sensors just not the o2
g2tegsown
Jul 1, 2008 08:39 PM
colnago
Apr 7, 2007 11:14 PM
D15JDMARIO
Mar 3, 2007 07:39 PM
Hoodwinked
Dec 1, 2003 12:13 PM
SIK IN DA HED
Nov 15, 2002 10:59 AM
