anyone with a JDM B16 i need help
i think my vaccum hoses are screwed up.
that thing in the top corner on top of the throttle cable what is that? where do the vaccum hoses connect to?
can someone get me better pictures to where that is supposed to go?
im having an idle problem and think it might be assosciated to that piece.
what is it called ?
i think that its somehow connected to the iacv, through the IM hole next to the throttle body.
what is it called ?
Re: anyone with a JDM B16 i need help (IVI)
are you asking for the sensor that connected to the vaccum hose? that is a map sensor. it go on top if the manifold. what year is the motor?
Re: anyone with a JDM B16 i need help (2lua)
no the map sensor i had connected there to make sure it get proper vaccum, since i was getting a code.
what i need is a diagram or pictures of someone elses jdm b16 with that thing in the top top corner some of it got cut off. i need to konw what that is, called, and where the hoses are supposed to plug into that.
i think one of the hoses goto the canister.
You talking about the metal thing in the top left corner?? Are you using a first gen b16?? Because i know my friends sir2 motor didnt have that. Can you get a picture of the whole manifold?
that's a 1st gen b16. 92+ civics dont need to use the vaccum diagram. just dont hook it up.
i have a 1st gen in my car. this is how i hooked up the vaccum stuff:
my map sensor mounted to the top of my TB just like stock. if it doesnt mount to the top of ur tb, there should be a nipple on the TB for the map sensor. you have the map sensor hooked up where the hose from the pcv valve. the jdm manifold lacks a nipple for the charcoal canister. if you dont hook up the canister, you wont throw a CEL. i just bought a usdm intake mani and throttle body to be smog legal
Beat me to it, but heres mine anyway.
I have a bored h22 tb now but it is all the same except for the throttle dashpot on top of the tb which had a line running from it to a third hole on the intake pipe
That piece doesn't do much, I know a few people who have just removed it with no problems but if you want to connect it to something it goes to the intake pipe
Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi »</TD></TR><TR><TD CLASS="quote">That piece doesn't do much, I know a few people who have just removed it with no problems but if you want to connect it to something it goes to the intake pipe</TD></TR></TABLE>
it sounds like its making the air come out of the top hole of my throttle body that specific valve i think its called a dashpot?
im not sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallAssFilipino »</TD></TR><TR><TD CLASS="quote">Is that a 5-lug conversion on a 4-door?</TD></TR></TABLE>
yes
im not sure.
yes
Re: (IVI)
i put a 1st gen B16 in a 89 hatch, all we did was take that thing off and thread a bolt down into the hole and ground it off. same witht he vacuum piece just to the right of it.
YOUR MOM
05-10-2009 09:10 PM
93civiccxhatch
11-06-2004 06:37 PM
T_Rex
05-14-2003 04:06 PM
