how to :bleed Clutch..?
Re: how to :bleed Clutch..? (BLUE EH3)
Fairly easy.
The blled screw down by your manifold. unscrew that and press teh clutch pedal down until the new fluid is there. Jsut tighten fill the fluid back up and pump teh pedal until it feels fine.
Electrician
Re: how to :bleed Clutch..? (egcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe »</TD></TR><TR><TD CLASS="quote">its just like the brakes, press the clutch like 3-4 times then hold down have sumone open the bleeder, then close it. repeat </TD></TR></TABLE>
That is SOO wrong. It doesn't work, one of my friends tried it.
The bleeder screw is right on the Slave Cylinder. Look down in front of transmission (in front of the radiator fan). You'll see a bleeder screw there. Looks like a nut with a hole on top of it, can't miss it. It's a 10mm (I think) screw. DEFINITELY use a Flare Nut wrench or Vise-Grips.
Have someone crack open the bleeder screw.
Push down on the clutch pedal.
Tighten bleeder screw.
Release clutch pedal (or grab it and bring it up if there is NO pressure).
Repeat until you have enough pressure (not too high).
I don't think the clutch builds pressure like the brakes do when you pump them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">i casnt find any good posts on this! hellp </TD></TR></TABLE>
I made a post on how to awhile so this should help: https://honda-tech.com/zerothread?id=787039
Re: how to :bleed Clutch..? (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">That is SOO wrong. It doesn't work, one of my friends tried it.
Repeat until you have enough pressure (not too high).</TD></TR></TABLE>
oh well thats how i was taught n we did it on frends car n it worked fine. its 9mm
theres nothin wrong with this
The fluid that's in your Clutch master cylinder is brake fluid. You should probably use the same type as you have in you Brake master cylinder. Probably DOT 3 brake fluid.
Re: how to :bleed Clutch..? (hatchbro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchbro »</TD></TR><TR><TD CLASS="quote">i use brake fluid for clutch also and used 10-30 oil for transmission too. Both work perfectly.</TD></TR></TABLE>
u used tranny oil for ur clutch?
Help we my pennies
Re: how to :bleed Clutch..? (Proglow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Proglow3 »</TD></TR><TR><TD CLASS="quote">I don't think that 10-30 oil for your transmission is the greatest fluids to use!</TD></TR></TABLE>
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchbro »</TD></TR><TR><TD CLASS="quote"> used 10-30 oil for transmission too.</TD></TR></TABLE>
Why not use the correct fluid? There is a reason why they make Manual Tranny Fluid and Automatic Tranny Fluid.
Electrician
Re: how to :bleed Clutch..? (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">
Why not use the correct fluid? There is a reason why they make Manual Tranny Fluid and Automatic Tranny Fluid.</TD></TR></TABLE>
Dude, those fluids are made for people who CARE about the life of their transmission and CARE about proper lubrication of all parts that have lots of friction between them. I guess they doubt Engineers made fluid for specific parts. It's only a "give me your money" gimmick. Come on now!
Electrician
oh well thats how i was taught n we did it on frends car n it worked fine. its 9mm</TD></TR></TABLE>
Are you sure?
Some retarded mechanic around me was doing the EXACT same thing for about, of I say, 30 minutes and NEVER built up any pressure. Just watching him bleed the clutch line from this other Honda and couldn't resist laughing. Had to tell him the proper way to do it and it was up to pressure within 20 seconds.
Are you sure?
