clutch problems
clutch problems
i changed a hydro. clutch in my 92 hatch. i drove it for a day and it seem cool. the next day as i was puling out of my garage i heard a sorta grinding noise as i was letting out the clutch. now it does it for nutral too i throught it might be my master slave cylinder b/c it was leaking a lil fluid. i got a knew one, bleed t one or twice.i stared it and it stil made the soound so i bleed it again and now the pedals dead it doesnt build any pressure to the slave cylinder. if i pump the control arm and crack the slave it spits so its holding pressure. but the pedals dead?? i dunno what to think?? please help.
Re: clutch problems (snatchbakman)
So did you change your master or slave cylinder? That is probably not related to the noise you are hearing, but if one is still leaking thats probably why you can't build pressure. If its leaking, its not working right.
Re: clutch problems (JDM-GTO)
the slave cylinder is hold pressure so its not the. do you think i could be my clutch cylinder b/c its leaking inside the car by the pedal?
so i replaced my slave cylinder and my master cylinder and i regained pressure from pedal. i bleed the line a few times. i figured i wasnt getting enough pressure to the throwout baering and that with the nosie might have been . welthast didnt work so i think my next move is to take the tranny back off and make sure everything ok in there.
Magicdrag0n
Transmission & Drivetrain
07-17-2018 01:33 AM
xsnrgsr
07-13-2003 08:23 PM
