Not your Typical OBD 2 to OBD 1 conversion...
Okay heres the scenario, I dropped a d16z6 into my 96 ek coupe that originally had a d16y7 which was originally OBD 2a. I'm using all OBD 1 components on the motor from starter to distributor to alternator, as well as the OBD 1 wiring harness. Heres the question, I have both parts of the OBD 1 harness as well as my stock OBD 2 engine harness, where does the engine harness interface with the interior harness (the wires that run the guage cluster, switches, and HVAC controls? I cant remember. Also is it as simple as hacking that plug off my OBD 2 harness and frankensteining (soldering it of course) it on the new OBD 1 harness? Somebody help. My built d16 turbo motor needs wiring. :thumbsup:
thankx in advance
Joel
thankx in advance
Joel
Re: Not your Typical OBD 2 to OBD 1 conversion... (Unsivil_audio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsivil_audio »</TD></TR><TR><TD CLASS="quote">Okay heres the scenario, I dropped a d16z6 into my 96 ek coupe that originally had a d16y7 which was originally OBD 2a. I'm using all OBD 1 components on the motor from starter to distributor to alternator, as well as the OBD 1 wiring harness. Heres the question, I have both parts of the OBD 1 harness as well as my stock OBD 2 engine harness, where does the engine harness interface with the interior harness (the wires that run the guage cluster, switches, and HVAC controls? I cant remember. Also is it as simple as hacking that plug off my OBD 2 harness and frankensteining (soldering it of course) it on the new OBD 1 harness? Somebody help. My built d16 turbo motor needs wiring. :thumbsup:
thankx in advance
Joel</TD></TR></TABLE>
I hope you can still pass emissions with that. I think it's actually illegal to downgrade an OBD system in a car.
thankx in advance
Your ODB2 harness interfaces with your dash harness just before the ecu. There is a green plug, probably 20 pins to it.
IDK how this works in regards toyour OBD1 harness though
vtec25
10-31-2006 10:38 AM
guyuenvy
05-16-2002 12:27 AM
