b16 sirII swap in 93 civic ex idle question?
just finished swapping a b16sir II motor in my 93 civic ex using a p30 jdm ecu and now when the car sits at idle the rpm's rev up and down unless i stay on the throttle til it gets above 3000 rpm any help or suggestions on how to solve this
Re: b16 sirII swap in 93 civic ex idle question? (ablack934doorcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ablack934doorcivic »</TD></TR><TR><TD CLASS="quote">just finished swapping a b16sir II motor in my 93 civic ex using a p30 jdm ecu and now when the car sits at idle the rpm's rev up and down unless i stay on the throttle til it gets above 3000 rpm any help or suggestions on how to solve this</TD></TR></TABLE>
Check the all the plugs in the back of the Intake manifold and around the Throttle and Body. I don't know what it is called though. It happened to me a week ago, I forgot to plug in one of them. That was my problem, good luck to yours.
Re: b16 sirII swap in 93 civic ex idle question? (LilSilver)
My friend had a similar problem with his prelude after swap'n in his frankenstein motor. Make shure that all of your vacume lines are all hooked up correctly, and that should fix the problem.
machoej1
02-02-2017 06:08 AM
igorka_91
11
12-24-2009 08:46 PM
tgkaotic
08-21-2007 03:38 AM
