EXHAUST HELP! (93 Si)
Mike Jones
OK, heres the deal..
Thought i had a header gasket leak. Bought a gasket, took off the heat shield....
OH NO!!!!! Header is cracked!! So i have 2 questions..
1. How do i get that stupid wire cluster running into the manifold off?!?!??! (it's the only thing preventing me from removing the heat shield)
2. Is there a fairly cheap performance header for the d16z6???
Appreciate it!
Appreciate it!
Re: EXHAUST HELP! (SlowPokeEg)
you are talking about the O2 sensor that protrudes through the heat shield. Just go to autozone, and rent the O2 sensor removal tool for like $5. its just a fancy socket that has a slit on the side so the wire won't be in the way of the nut. Be abit careful removing it, I have heard they break alot. I removed mine just fine, kept the tool since it was only $5. The header is easy to remove after that. Think the nuts/bolt are 14mm.
lochenjons
02-07-2012 03:33 AM
WheaMyRyceGo
02-10-2008 03:52 PM
pli
41
02-27-2007 05:49 AM
