Acura Legend Throttle body work on B-series?
there's a guy on ebay selling a 62mm t-body, he claims it will work on a b16, but it seems like it's a way different motor. Anyone know for sure?
Re: Acura Legend Throttle body work on B-series? (thehatchninja)
the top one is the legend tb....it seems to be missing a sensor, i don't know if it's been taken off or if it doesn't have a place for one....i know it has the tps sensor, the bolt pattern seems to be the same tho. the hoses are also different, the only thing that worries me is that sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">is there a place for the MAp</TD></TR></TABLE>
That's my Q....researching it now
Re: (thehatchninja)
http://www.acura-legend.com/vb...+body
here's a link to a legend site with more pics of the Legend TB....it's a write up on a coolant bypass, it doesn't look like there is a place for the MAP sensor
Re: Acura Legend Throttle body work on B-series? (civic dx)
plus it looks like there is no place for the MAP
the guy sellin it is a liar
of course there is a place for a map sensor what do you think the vacuum port on top is for? a LOT of hondas use a firewall mounted map sensor...
but i also tend to think the bolts may not line up...
Re: (b18bEG)
3 of the bolts do look like they line up....wouldn't be hard to drill the 4th (bottom right
here's the problem.
no MAP sensor on top.....i don't know about a firewall mounted whatever......ideas?
here's the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">plus it looks like there is no place for the MAP
the guy sellin it is a liar</TD></TR></TABLE>
maybe it has a external map sensor?
Re: Acura Legend Throttle body work on B-series? (lax1185)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lax1185 »</TD></TR><TR><TD CLASS="quote">Throttle assembly looks like it would be more of a problem than the MAP sensor. </TD></TR></TABLE>
bolts right up, i have done it before, if you cant find a h22 TB use a Legend TB hehehe
Modified by JDMFreak at 3:34 PM 11/6/2004
Re: (thehatchninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">no MAP sensor on top.....i don't know about a firewall mounted whatever......ideas?</TD></TR></TABLE>
Its real easy to do. Just run a vacuume line to the nipple on the sensor.
Re: (thehatchninja)
doesn't the legend engine have more power than a b16 stock...i think the legend is like 210-220..it is 2.2 liter i believe why would u swap the throttle body?
Re: (thehatchninja)
well if ur lookin for more power just save for a aftermarket one like a jackson racing one but thats all up to you and your wallet
EgSalad
06-06-2007 12:12 PM
civichatch67
09-21-2005 10:11 AM
comptechgsr2000
05-08-2002 03:53 PM
