First Mods
First Mods
I was thinking about putting on a header and exhaust system, intake, and lowering springs as the first mod. My local import shop estimated me about $800-$900(i already have the header), are these what is should be looking for first or should i be looking for something different
I have a '98 Civic EX
Re: First Mods (simmons442)
Do what you want. That's my official statement on the matter. The TOS for the forum says you should search and check out the site and not make general questions such as this, but since you asked with certian questions, I'll bite.
800-900 is rediculous for what you're trying to get. A cat back exhaust should be somewhere between 200-500 dollars, depending on what you get (custom vs. pre-fab) and springs run somewhere around 150 dollars.
If you can turn a wrench at all you can install a header and an exhaust in less than an afternoon. Springs aern't hard either if your brave enough to do it.
I/H/E and springs sounds like a pretty good start. after that it really depends whether you want to go all motor, forced induction, or go looks and get a body kit or something
900$ for 10 hp. not worth it IMO. save for turbo kit or get nitrous.
get a ride in a turboed/nitroused civic. then ride in a I/H/E civic. you'll kick your own *** for ever thinking of I/H/E.
I know I did.
I know I did.
if you're spending that much ($900), i'd personally upgrade the suspension as much as possible (coilovers, sway bars, etc).
what are you planning to do with this car anyways?
H-T Order of Merit
I would say suspension upgrades and learning the limits of your car is always a good option before adding more power than you might be able to handle.
If you plan on swapping eventually then you may want to hold off on parts that won't swap over to the motor you plan to swap to.
I am a (Trial User) Army
Re: First Mods (SprayinR21)
I know alot of you are recommending turbo or nitrous as good mods for his $900 that he has to spend, but you have to remember two things.
1) These are his first mods. He is saying that he will be getting a shop to put on his header, springs, etc...therefore, there is no way that he will know how to install a custom turbo kit on his car, let alone find good deals on the parts. I'm willing to bet that 1 out of a 100 people on this thread know how to install a custom turbo kit properly.
2) You are recommending these radical high performance upgrades out of hindsight. If you think back, what were your first mods before you became the knowledgeable enthusiasts that you are today? Probably, I/E and some light suspension work like springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simmons442 »</TD></TR><TR><TD CLASS="quote">I was thinking about putting on a header and exhaust system, intake, and lowering springs as the first mod. My local import shop estimated me about $800-$900(i already have the header), are these what is should be looking for first or should i be looking for something different
I have a '98 Civic EX</TD></TR></TABLE>
To the original poster, IMO I/H/E and lowering springs are a good start for your honda. You'll have a little more power than stock and you'll be able to navigate through turns alot better. Instead of getting a shop to install your parts, you should buy a helms manual, get a good tool set and spend the weekend modding your car. You'll learn a hell of a lot about how cars work and you'll feel really proud. You might save a little money in the process too
ive put together 2 turbo kits for stock d16s and i do agree with you that this guy is just starting and dont know much and i agree with intake and cat-back exhaust and some nice coilovers, but if he knew someone that knew some about cars a 50 shot of nitrous wouldnt be too bad for the car either
Re: First Mods (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">I know alot of you are recommending turbo or nitrous as good mods for his $900 that he has to spend, but you have to remember two things.
2) You are recommending these radical high performance upgrades out of hindsight. If you think back, what were your first mods before you became the knowledgeable enthusiasts that you are today? Probably, I/E and some light suspension work like springs. </TD></TR></TABLE>
Learning how to mod your own car is always best for a beginner to learner more about their own car. Helps to strengthen their confidence to do later upgrades/mods themselves. Of course doing your own research is the key. My first mod was replacing the cut springs that the previous owner had put on my 94 ex. I didn't know anything about. Friend gave me his manual and said here you go, call me when its all done. The one thing I missed was that the mounting bracket needs an allen wrench to help remove the size 14mm nut. I nearly replaced the whole assembly, when a clerk at autozone pointed it out, haha. Now I'm doing a b16 swap. yeah yeah a b16 because its all I can afford....
And out of this hindsight, it would have saved US and HIM money in the long run - so why let this guy learn the hard way??
So to the OP: What are your plans for the vehicle?
If you plan to swap, I/H/E for the SOHC ain't gonna work with the DOHC....so pay a little money now to go a little faster (which is still slow in the grander scheme of things) or wait and save, do the swap and be that much further ahead of the game and that much faster.
Re: First Mods (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">
Let this guy learn the hard way? What are you talking about? The best way to learn is to start with the easier stuff. It's like anything in life. You can't run if you don't know how to walk. You can't install a turbo kit if you don't know how to install an intake.
If he wants to actually learn and do mods himself, telling this guy to install a turbo kit right away is bad advice. Period.
If you plan to swap, I/H/E for the SOHC ain't gonna work with the DOHC....so pay a little money now to go a little faster (which is still slow in the grander scheme of things) or wait and save, do the swap and be that much further ahead of the game and that much faster.</TD></TR></TABLE>
That is good advice. Your D16z6 parts won't work on any B series motor and chances are you'll develop an urge to swap after you get tired of your power output.
I say to do what you want and spend what you want, but get your money's owrth and do your own work. For me that is what this is about.
Get some good tires, brakes, and a decent suspension set-up. IMO, it's very important to set a good platform for future mods.
Economic Upturn, WUT
Location: Alittle Placed Called None of Your Damn Business.
Re: First Mods (StrikerX)
just turbo your D series, produce more power then all of these swaps .. well most of them, you could build your own for 1000$.
::EDIT::
didn't read down farther, header would be simple, as would exhaust. Springs you just need a compressor for them, but go with coilovers so you can adjust dampness and ride height, camber kit, sway bars, all of the goodies to stiffin up your car.
::EDIT::
