Hard to shift into gears in the morning, help!!
Old 03-27-2005, 11:38 AM
kinvid22's Avatar
Default Hard to shift into gears in the morning, help!!
This GSR tranny has only seen 40k miles, doesn't grind at all. But just last week, start the car in the morning, it was pretty tough to shift into into 1st or reverse. It never happen like that before, just last week. I had to use force or shove it into gear. I change the tranny fluid 15k miles ago....maybe i need to change it again?
From that day on, I will have a hard time going into any gears, but always in the morning when the car is cold. Then throughout the day, it would be ok, but seems a little notchy shifting into gears. The clutch is not going bad I would think.
I also noticed the clutch petal is a little spongy. Meaning it's been softer than lately to push the clutch petal to the floor or it has a shorter distance to the floor than before.
Another thing is the clutch fluid system has about 80,000 on it, I don't think it has been changed before.
I need some help guys.
Modified by kinvid at 12:59 PM 3/27/2005
Old 03-27-2005, 12:13 PM
nub.96ek's Avatar
Default Re: Hard to shift into gears in the morning, help!! (kinvid)
Change your fluid and make sure it's the right weight [use honda brand at least].
It may also be your shifter bushings [happened to me]... or if you bottomed out recently you may have bent your shift linkage [happened to a friend]...
Check the fluid in your clutch MC and make sure your slave cylinder is working properly as well.
These are the cheapest thigs it may be so I would check all of those first.
Did you recently put in a short throw? - thats when mine started doing it and when I replaced the shifter bushings it stopped.
Old 03-27-2005, 12:44 PM
JohnnyEH2's Avatar
same thing with me.. first and reverse are kinda of hard to shift into when i havent driven over night or a while, but its been like that for me forever (gsr tranny)
Old 03-27-2005, 12:45 PM
Multi-paradigm
Good ol' Screwtape's Avatar
Default Re: Hard to shift into gears in the morning, help!! (Johnnay)
check clutch fluid.
Old 03-27-2005, 01:41 PM
kinvid22's Avatar
Default Re: Hard to shift into gears in the morning, help!! (Screwtape:)
hmm..i don't think short shifter is bad or touch anything...
Old 03-27-2005, 02:06 PM
HT Order of Merit
JDM_Ej's Avatar
Change your transmission fluid.
Old 03-27-2005, 03:40 PM
Bond's Avatar
Default Re: Hard to shift into gears in the morning, help!! (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Change your transmission fluid. </TD></TR></TABLE>
I would highly suggest doing this. Most likely your tranny fluid is low and when it's cold it will make it harder to put in gear. Just change it and make sure it is at the right level.
Old 03-27-2005, 04:35 PM
dgrave's Avatar
Do some check ups... check the clutch slave and master cylinder make sure they not leaking... make sure u not losing tranny fluid...check tranny bolts... sounds like your clutch slave cylinder.. but.. check it all out.. goodluck
Old 03-27-2005, 11:18 PM
kinvid22's Avatar
Default Re: Hard to shift into gears in the morning, help!! (dgrave)
cool guys, i will check all of these out, see what happens, and report back at ya
hojoR
08-16-2009 08:32 PM
killyourscene
Honda Civic (2006 - 2015)
39
01-27-2008 09:21 PM
94DCTeg
12-10-2007 07:22 AM
PatrickGSR94
04-23-2003 11:05 AM
p0pe
08-13-2002 12:57 PM
Quick Reply: Hard to shift into gears in the morning, help!!
