Oil Pan Tap
Oil Pan Tap
I've been searching for how to do an oil pan tap and all I seem to find is where to place it, etc.. but no walk through.
Can anyone link me to a step by step oil pan tap?
thanks
thanks
Re: Oil Pan Tap (discrete)
If you know were to drill it then there is only 3 steps.
1. Drill your hole
2. Weld fitting
3. Connect oil line
Im assuming you know that you have to remove the oil pan from the block first.
1. Drill your hole
2. Weld fitting
3. Connect oil line
Stewie
Welding / Fabrication
11-09-2005 08:38 AM
Sinner
10-08-2004 09:21 AM
