why would the motor start but not go in gear?
Re: why would the motor start but not go in gear? (Sleepin Si)
can you out a clutch on with a alignment tool on a stock d15 tranny or i have a tool for clutchmasters clutch, will that work?
Re: why would the motor start but not go in gear? (jh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh »</TD></TR><TR><TD CLASS="quote">can you out a clutch on with a alignment tool on a stock d15 tranny or i have a tool for clutchmasters clutch, will that work?</TD></TR></TABLE>
Huh?
Huh?
Re: why would the motor start but not go in gear? (EL Vap133)
can you change out a clutch without a alignment tool on a stock d15 tranny or i have a tool for clutchmasters clutch, will that work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh »</TD></TR><TR><TD CLASS="quote">can you change out a clutch without a alignment tool on a stock d15 tranny or i have a tool for clutchmasters clutch, will that work?
1 question is maybe you can try.
2 question you mean by using the aligment tool came from the cm kit you got? if it fit then yes.
Re: why would the motor start but not go in gear? (2lua)
could be a couple things, shift fork inside tranny could be bent. shift linkage could be bent+ what everyone else said.
when you start up the car, and try putting it in first does it feel like the car is going to bog or try to lurch forward? if so, then it's gonna be the clutch itself, if not also check master cyl.
90hatchie
11-10-2004 12:04 PM
