!!Need Help!! STARTING PROBLEMS 93 CivicEX
I am in need of some help with my 93 Honda Civic EX..
Ive been having starting problems after short and long drives..
These are the things that have been checked/changed..
*Main Relay
*Distributor Coil
*Igniter
*Fuel Filter
*Battery is fine
*The spark plugs good
I need some advice..
THANKS
*Main Relay
*Distributor Coil
*Igniter
*Fuel Filter
*Battery is fine
THANKS
Re: !!Need Help!! STARTING PROBLEMS 93 CivicEX (apos)
When you drive the car does it sputter and delay while accelerating?
Why didn't you change your distributor cap/rotor when you changed the coil????? Are you running an external coil for some reason?
Re: !!Need Help!! STARTING PROBLEMS 93 CivicEX (VTiVTo8000rpm)
yeah it kinda lags when it starts...
at times it starts clean, but there are also times when it sputters..
Ssauber21
01-14-2013 10:05 PM
