SRS Light On in my Civic 94
Hi, I am new in this forum, I recently got a used Civic 94 Coupe EX, it has the SRS Light on all the time, I think it had problem with the AirBag so I just like to eliminate or disconnect this light from the dash, anyone knows how I can do it?.
Any help will be greatly appreciate.
Re: SRS Light On in my Civic 94 (Alejandro)
remove the screws behind the gauge cluster and remove the bulb. but i think there is a way to reset it, but im not sure, try doing a search
Re: SRS Light On in my Civic 94 (civiccpedx)
I think your best bet is to figure out the problem and fix it properly.. Theres a thread around here that shows how to check to see what light its throwing.. DO a search..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx »</TD></TR><TR><TD CLASS="quote">remove the screws behind the gauge cluster and remove the bulb. but i think there is a way to reset it, but im not sure, try doing a search</TD></TR></TABLE>
please do not give false information. there are no screws in the back of the cluster and there is no bulb that u have to remove. its a plug. and yes u can reset it. the only thing u got right is the search part because this has been coverd many time. your score- 2/3 =33% YOU FAIL!!
Re: SRS Light On in my Civic 94 (93ejay1)
http://www.superhonda.com/foru...t=srs
This might help, SRS was remove on an accord...
Thanks for all yours answers. I fixed the problems following these easy instructions on this forum.
Again thanks to everybody.
Alejandro
Alejandro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">
please do not give false information. there are no screws in the back of the cluster and there is no bulb that u have to remove. its a plug. and yes u can reset it. the only thing u got right is the search part because this has been coverd many time. your score- 2/3 =33% YOU FAIL!!</TD></TR></TABLE>
Hey dipstick, before you start clownin, check your mathmatics 2 out of 3 aint 33%.
CaRiXma
04-13-2003 09:51 AM
C-speed
09-06-2001 08:07 PM
