can a p72 gsr obd1 ECU be chipet?
Re: (ted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ted »</TD></TR><TR><TD CLASS="quote">would it be a better ecu to use on my b18c swap or would a p28 be better chipet thanks for the HELP!!!!</TD></TR></TABLE>
Both will act the same with the exception of the P72 being able to monitor the knock sensor. Not THAT important to say the least.
TSPeed Factory
Re: (Hybrid93Eg)
with a rechipped p28, in uberdata it has an option for knock sensor or not. you can also add IABs on a p28 as well. whats your setup?
Re: (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">with a rechipped p28, in uberdata it has an option for knock sensor or not. you can also add IABs on a p28 as well. whats your setup?</TD></TR></TABLE>
Sure you can TOGGLE the option on or off. Any rom editor will allow you to do that. But simply toggling it on doesn't mean its going to work. Considering a P28 doesn't have a knock board and also no circuitry to control IABS, without doing some soldering its NOT going to do anything. Go ahead, enabled the knock sensor and burn a chip. Stick it in your P28 and tell me what you get.
ted
03-25-2005 05:31 PM
