idle problems
idle problems
i have a ls vtec setup and when i turn my car on it revs all the way to 3000 and after a min or two it starts idleing from 1000 rpm to 2000 rpm and it never stops even when im drivind it does that. i searched but i couldnt find anything i need help quick
Re: idle problems (crxomar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxomar »</TD></TR><TR><TD CLASS="quote">i have a ls vtec setup and when i turn my car on it revs all the way to 3000 and after a min or two it starts idleing from 1000 rpm to 2000 rpm and it never stops even when im drivind it does that. i searched but i couldnt find anything i need help quick</TD></TR></TABLE>
are you sure?
try type in surge or idle.
are you sure?
Re: idle problems (2lua)
Okay one of two things could be happening. #1, the Idle Air Controller (IAC) is bad, which is located on the intake manifold, and it has a black selenoid on it. Check the connector. #2, you're not getting coolant to the IAC, cuz you'll notice there are two hoses that go into the IAC which consist of coolant which operates the IAC. Start from there. Let me know how things go.
Re: idle problems (JDM_Ej)
Yeah well a million things is right. You could say a bad head gasket is leading to overheating, and leading to coolant loss, leading to the IAC acting up, leading to idling problems. I just listed the two most common remedies.
Well I found the problem it was inside tthe throttle body a little whole. I guess i need a new tb put i just put something in their for now to cover it and it stopped. Does anyone know the name of what im talking about?Thanks
