Need help with 92 cx hatch
i have a 92 hatch cx. i just changed the timing belt, and the car feels weak.
when i try to drive it, it feels like the car looses power, and im pretty sure the car doesnt need a new clutch. it also vibrates alot
by the way, i bought the car with no timing belt.
also i have changed the spark plug
ya are you positive u lined the crank up to the tdc mark and set the cam with the word up facing straight up?? you could have it off a tooth or 2
yea check the tdc mark or even the plug wires, as for the vibration could e a number of things like tire balance, ball joints, suspension etc.
Re: Need help with 92 cx hatch (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">its a cx
thats why
but check the compression</TD></TR></TABLE>
thats why
Re: Need help with 92 cx hatch (joon)
haha uh. dude ur timing is definetly off. if it was right, u'd jus feel the same power as before. cx is weak but its not like WHOA THATS WEAK...less ur goin up hill but yea. ur timing is off. check it real carefully. then rotate it twice. then see if everythings lined up. im pretty sure its that. no way would a timing belt kill power if it was put on correctly.
if u want u can come up here and i can check ur belt for u.... i used to have a cx and my t belt slipped when i bought it cuz i revved that bitch out and i can tell its like holy crap its slow when its off a tooth
Re: (siregcivic)
yeah, timing was sure off. Thanks Guys. Now i havwe another question.
when i plug my right turn plug(the one that holds the light bulb for the turn signal) my right turn signal stay on, on my cluster.
What is up? can it be wiring problems?
eghatchfla
05-22-2010 07:38 AM
compwc18
09-05-2004 02:47 PM
