5 inch tach
Re: 5 inch tach (OsNApArAvEr)
ok i believe it should be as follows: the red wire connects to the positive side of the battery, the black is the ground, the green is for the distributor or distributor signal, and the white goes to the accessory power. im not for sure but i believe this is how it is supposed to wire it.
Re: 5 inch tach (JDMSiGuy17)
correct. and the other wires(if there are any they are brown and i belive purple) are suppose to be cut to tell how many cylinder motor you have. or something like that. i know some are like that.
Re: (OsNApArAvEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OsNApArAvEr »</TD></TR><TR><TD CLASS="quote">well im sorry my car didnt come with a tach is it to much to ask?</TD></TR></TABLE>
hell no it aint.
good luck with the install.
hell no it aint.
Re: 5 inch tach (GreyDel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreyDel »</TD></TR><TR><TD CLASS="quote">5 inch tach whats wrong with the stock gague clusters that have a tach in them?</TD></TR></TABLE>
i've noticed that the stock gauge tach is about 200-300 rpm off (esp in the upper rpm band) so aftermarket tach's are worth it IMO...
Re: (rw92civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rw92civic »</TD></TR><TR><TD CLASS="quote">well i dunno bout u but no one needs a big tach in there window and a shift light to blind the hell outta ya sooooooo 5' tach = </TD></TR></TABLE>
What this guy is saying in no diplomatic fashion at all is get a cluster out of an Si or Ex, they have the stock tach in there. Some guys like the big tachs but Id rather keep myself under the radar from Johnny Law.
Re: (R81DC4LS)
the bigger the tach, the bigger of a target your car is for theft. that's the way I see it. I just run the stock tach, and take mental note of how far off the rpms are.
my car didn't have a tach and i installed a 3" super tach II...
red = fuse panel
black = chasis
white = red and black wire on dimmer switch
green = blue wire on the left side of your gages, on the back. left side looking at it from the front. so your temp gauge. that way you don't need to find a way past the firewall. i just installed mine today
red = fuse panel
black = chasis
