air/fuel guage install
Re: air/fuel guage install (disposable)
https://honda-tech.com/zerothread?id=683978
you gotta learn to search.
and i think the green wire goes to your o2 if im not mistaken.
Modified by _B_Series_ at 1:17 PM 8/23/2005
Re: air/fuel guage install (_B_Series_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _B_Series_ »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerosearch
and i think the green wire goes to your o2 if im not mistaken.</TD></TR></TABLE>
you are mistaken all 4 wire go to the O2 sensor, one black one is the heater wire, one black on is the o2 12v green is ground white is signal
Re: air/fuel guage install (tuck'd98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 »</TD></TR><TR><TD CLASS="quote">
you are mistaken all 4 wire go to the O2 sensor, one black one is the heater wire, one black on is the o2 12v green is ground white is signal</TD></TR></TABLE>
actually i was talking about just running straight to the o2 sensor, but yeh your better off running it to the ecu.
Re: air/fuel guage install (DutchEG6)
If it were me, i would put the + on any hot ignition switched wire, the - on any ground, and the signal wire on a wideband o2. It doesn't matter where the guage gets power from, just the signal. And the signal from a stock o2 is completely worthless as far as a guage is concerned.
wickedxboi
03-22-2003 01:51 PM
