DIY: Paint windshield cowl
Old 08-22-2005, 04:25 PM
copperfox's Avatar
Default DIY: Paint windshield cowl
This DIY procedure applies to 92-95 civics. Other models are probably similar but not exactly the same.
Materials: 10mm socket, 14mm socket, socket wrench, bug and tar remover (or a general degreaser), non-lint cloth, gloss black spray paint, Duplicolor bumper and trim spray paint, newspaper, masking tape, a buddy.
1. Remove Hood by taking off the two 10mm bolts attached at either hinge (4 in all). Have your buddy hold the hood upright while you remove the bolts. Disconnect rubber wiper fluid line.
2. Remove Wiper arms by taking off the 14mm nuts (1 per arm).
This is what you have: (hopefully your hood is in better shape )
3. Take the newspaper and masking tape and begin to mask off the surrounding area as seen here:
4. Continue masking until you are sure no overspray will touch your car's paint. Remember that accidental overspray on glass can be scraped off with a razor blade when dry. Don't forget to mask the wiper arm bolts!
5. Wipe the entire cowl down with a degreaser or Bug and Tar remover and your lint free cloth. Goo Gone works too.
6. Shake the Duplicolor Bumper and Trim spray paint per the directions on the can. Spray the cowl, doing your best to keep the can upright (quite difficult).
Here is a closer shot:
7. While that dries, wipe down the wiper arms with the same degreaser, let it air dry, then coat with gloss spray paint. (I have found that flat black fades quickly in the sun)
Here is the finished cowl!! (Ignore the rusty hinges!!! )
Old 08-22-2005, 04:36 PM
I am a (Trial User) Army
litterbox's Avatar
Default Re: DIY: Paint windshield cowl (copperfox)
WOW, LOOKS 1000x BETTER. Oops, caps. I need to do this!
Old 08-22-2005, 04:41 PM
Moderator
chad's Avatar
Default Re: DIY: Paint windshield cowl (litterbox)
a normal person would have taken this piece off and painted it!
Old 08-22-2005, 04:50 PM
adictionbass's Avatar
Default Re: DIY: Paint windshield cowl (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">a normal person would have taken this piece off and painted it!</TD></TR></TABLE>
Old 08-22-2005, 04:56 PM
junior40er's Avatar
Thats what me and my brother have been thinking of doing to our hatch back but since the car is white and we paid over 2grand for paint job we do want to risk overspray. Does any one know how to take that piece off?
Old 08-22-2005, 05:11 PM
Paprika's Avatar
Dispite the procedure, it's a good writeup.
Old 08-22-2005, 05:13 PM
rabius's Avatar
if the paint is more than like, a month or two old, you can lightly wipe little bits of fresh overspray off with lacquer thinner, as long as you dont scrub for more than a second or two in one spot, it wont harm the paint.
LShatchie's Avatar
Default Re: DIY: Paint windshield cowl (junior40er)
I think you just pop off all the plastic screw covers then unscrew it, and bam its off, of course after you take the wipers off .
Old 08-22-2005, 05:33 PM
civic_speed99's Avatar
I need to do this. Good work.
Old 08-22-2005, 05:55 PM
mike93eh
Guest
Posts: n/a
ok....so why did you paint it again??
looked alright to me :shrugs:
Old 08-22-2005, 06:01 PM
ThatsMyEG's Avatar
Default Re: (mike93eh)
i painted mine yesterday took about a total of 5-10 mins to take it off. its just a couple clips i also left my hood on...but i guess it dont matter how you do it..
Old 08-22-2005, 06:06 PM
Mine needs paint because it is fading bad. I have used back to black on it weekly and it doesn't look any better.
Old 08-22-2005, 06:13 PM
TypeRobert's Avatar
Default Re: (civic_speed99)
omg this is awesome y didnt i think of that went from not shiny to shiny ooooh c'mon
Old 08-22-2005, 07:13 PM
A-busive's Avatar
Nice job
Old 08-22-2005, 07:18 PM
sohcvtec1995's Avatar
Default Re: DIY: Paint windshield cowl (A-busive)
Nice write up. Gives me something to do tommarow.
Old 08-22-2005, 07:21 PM
RangerDan's Avatar
Normally you wouldnt want to paint your wiper blades gloss black. Flat black helps reduce reflection and glare from the sun. But hey youll look great in your sunglasses.
Its a well done step by step diy but taking the cowl off is so much easier...personally I wouldnt paint one ever.
Old 08-22-2005, 07:39 PM
Civic4less's Avatar
Default Re: DIY: Paint windshield cowl (RangerDan)
Wow it looks so much better!! I'm gonna have to do this when I drop in the new(er) motor. Will this stuff work for the side trim peices???
Old 08-22-2005, 07:52 PM
mike93eh
Guest
Posts: n/a
Default Re: DIY: Paint windshield cowl (Civic4less)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic4less &raquo;</TD></TR><TR><TD CLASS="quote"> Will this stuff work for the side trim peices??? </TD></TR></TABLE>
nope. duplicolor bumper and trim paint ONLY works on wiper cowls. its specifically designed for them.
Old 08-22-2005, 07:57 PM
94_HATCH's Avatar
Gonna have to do this when im bored sometime
Old 08-22-2005, 09:09 PM
lazybrown187's Avatar
Default Re: DIY: Paint windshield cowl (adictionbass)
ME TOO I WOULD OF TAKEN IT OFF THE CAR TO PAINT IT AS WELL;BUT LOOKS GOOD THOUGH
Old 08-22-2005, 09:10 PM
howangseg's Avatar
Default Re: DIY: Paint windshield cowl (lazybrown187)
looks good
Old 08-22-2005, 10:03 PM
eJone powereD's Avatar
been meaing to do that to my car...i think i should now
Old 08-22-2005, 10:11 PM
Aphelion's Avatar
Default Re: DIY: Paint windshield cowl (eJone powereD)
great writeup, though you could've just taken the piece off, like everyone said. anyway, this is a great thread for reminding ppl about that piece, and how it needs to be painted just like the other exterior plastic pieces
Old 08-22-2005, 11:45 PM
myke's Avatar
Location: South LA...107th and fig to be exact...for the foo
Default Re: DIY: Paint windshield cowl (Aphelion)
isnt it easier to just take it off
Old 08-23-2005, 12:21 AM
Kaji's Avatar
Something so easy would be so ridiculously easy that it would not warrent any DIY praise and respect.
Quick Reply: DIY: Paint windshield cowl
