Check engine problem code 1 Help!!
Old Aug 21, 2005 | 03:18 PM
supra8civic's Avatar
Default Check engine problem code 1 Help!!
My check engine light keeps coming on. It gives a code 1, for oxygen sensor. The oxygen sensor is new and it still gives the code. I just put dc sport 4-1 header. I believe that the header is making the ecu give this code. If anyone has had this problem. Please let me know how to fix it. I have done other work to the engine. If anyone has any ideas??
Old Aug 21, 2005 | 03:25 PM
JDMlyfestyle's Avatar
did you happen to reset the ECU? sometimes the ECU will not clear the code unless it is reset
Old Aug 21, 2005 | 03:27 PM
Default Re: (JDMlyfestyle)
ya i have reset the ecm many of times and it is stays off for a little then it just comes back on
Old Aug 21, 2005 | 03:35 PM
jayswift's Avatar
Default Re: (supra8civic)
i'm assuming you had to extend the O2 sensor to reach the bung on the DC header correct? if so, check the wiring.
Old Aug 21, 2005 | 03:42 PM
Default Re: (jayswift)
yes the sensor had to be extended. The wires are fine. All are connected good. I think maybe the back pressure from the header is maybe different than the stock header.
dusterbd13
Oct 20, 2009 01:15 PM
sick93sol
Jul 29, 2007 09:43 PM
YaMaJeSty
Jul 26, 2002 04:01 AM
ITR#97-0039
Jan 16, 2002 02:51 PM
