EK Power Window Problem *Please Help*
Old 08-21-2005, 10:02 PM
Danger69's Avatar
Default EK Power Window Problem *Please Help*
Recently my passenger window is acting up. It won't align back up when I roll the window up it pushes the window forward so it pops out of the strip a bit. *Bottom right pic*. I have been adjusting the nuts on the power window assembly. *Left side pics*. I also tried adjusting the track where the window sits *bottom right pic* and still nothing. Can someone help me. I want to tint my window and install my new auto roll up alarm but this is holding me back. And it sucks that I have to keep that window up all the time or else it will ruin my weather stripping.
Old 08-21-2005, 10:55 PM
00ekcoupe's Avatar
Default Re: EK Power Window Problem *Please Help* (Danger69)
Seems like this is a common problem with our civics. I had the same problem with my 00 ex, but on my driver side window. Here's a link to my thread which people were a lot of help: https://honda-tech.com/zerothread?id=1303052.
I still haven't figured out the problem with mine. The only solution I can think of is I need a new regulator and/or motor. Whenever I want to roll my window down, I have to assist it by pushing the window down while it goes down. This is starting to get very annoying. I'm just too lazy to get a regulator I guess. Hope my thread helps, and if it does tell us what you did to fix it.
Modified by 00ekcoupe at 12:53 AM 8/22/2005
Old 08-21-2005, 10:56 PM
808_si's Avatar
my window did that about a month ago, i just put it back on track and it was good to go. There is a bolt on the bottom right (next to the speaker whole) loosen it all the way, and put it on track again. Spray the tracks with silicon lubricant, it makes them go up and down faster. if that doesn't help search there has been write ups on this before...
It wasn't very hard, only thing I had a hard time with was getting the door panel back on
Old 08-21-2005, 10:57 PM
00ekcoupe's Avatar
Old 08-21-2005, 11:19 PM
Danger69's Avatar
Default Re: EK Power Window Problem *Please Help* (00ekcoupe)
808_Si if you can get me a pic that would definitely help. yeah I understand how hard it is to get that panel back into place. The bolts I've messed with that is in the diagram is #23 is that the one you unscrewed? And to make it clear your driverside window is the one you fixed correct? What do you mean when you put it back on the track?
Old 08-22-2005, 12:07 AM
808_si's Avatar
Here is an awesome writeup. just take your time and go slow.
http://www.clubcivic.com/board...61119
Old 08-22-2005, 03:03 AM
NAEK's Avatar
my driver side door does that and i just roll my window half way down and push in from the outside and roll it up...
Old 08-22-2005, 03:30 AM
808_si's Avatar
use the writeup i posted above, i'm a noob and I did it in about an hour with no pictures and minimal instructions...
Old 08-22-2005, 04:52 AM
monicle's Avatar
there are 2 bolts that hold the front support track in place. (piece closest to bolt number 23 in the reference scematic posted. Those are the only ones that you should be moving. and it will adjust the angle of the window.
Old 08-22-2005, 10:37 AM
Danger69's Avatar
Default Re: EK Power Window Problem *Please Help* (monicle)
Thanks 808. I think I have to try the special case problem. Now when you say put two washers on the bolt that holds the window track. Do you mean I put two washers between the window track and the door panel then bolt it up?
Old 08-22-2005, 11:32 AM
hybridej7's Avatar
common honda problem. happened on my 97 civic since day one and my girls 97 CL since day one......hasnt happened in awhile, its been ok. i went to advance and bought a can of silicone spray, sprayed down the components and the window tracks, been fine. do that about once a month a you should be straight....
Old 08-27-2005, 01:18 PM
Danger69's Avatar
Default same problem
I did everything and still no go. Thing of it like this when the window goes up 3/4 of the way the left side of the window which is the side where my tweeter tilts downwards slightly and the right side eventually doesn't sit into the weather stripping leaving a slight gap. So basically the left side of the window needs to be pushed up more so when it reaches the top it is even and not tilted.
Old 09-11-2005, 11:01 AM
Danger69's Avatar
Default FIXED!!!!
I finally found what was wrong. When I was about to give up a 10mm nut fell out. I looked around and I found out that it was one of the bolts that holds up the up/down mechanism. I retightened it and all is well now. So if anything like this happens make sure all your bolts are tight.
Old 09-11-2005, 11:28 AM
vosburgtransport's Avatar
Default Re: FIXED!!!! (Danger69)
it did it to me on both my windows........ i got a 00 si!!!!!!
Old 09-11-2005, 01:49 PM
Danger69's Avatar
Default Re: FIXED!!!! (vosburgtransport)
Your going to have to pull out your panel and peel back the weather plastic cover. Check all the bolts that hold the power window mechanism in place. Check your window tracks rubber to make sure its not binding the window.
Old 09-11-2005, 02:37 PM
_ma
_ma's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vosburgtransport &raquo;</TD></TR><TR><TD CLASS="quote">it did it to me on both my windows........ i got a 00 si!!!!!!</TD></TR></TABLE>
holy owned lol!
I have the same problem with my manual window-driver side in a 97. I left it alone but I can crack open the window about 4-5 inches max without it coming out off track. Takes me about an hour to get the glass rolled up and on track.
So I guess I will be ordering some new window track rubbers and hopefully it works I wanted to tint and put alarm too
hondaEg_808
11-30-2010 12:35 AM
Leets
13
03-23-2005 04:38 AM
ericlee303
06-24-2004 06:01 PM
Quick Reply: EK Power Window Problem *Please Help*
