Brake light comes on when I take a turn?
Old 08-23-2005, 08:43 AM
DaveSi677's Avatar
Default Brake light comes on when I take a turn?
I have noticed that my brake light comes on when I take some sharp turn or even lightly sharp turns? could it be there is not enought brake fluid or an adjustment?
Dave
Old 08-23-2005, 08:51 AM
iaredavid's Avatar
Default Re: Brake light comes on when I take a turn? (93SiVtec677)
by assuming such, didnt you pop your hood and check the brake fluid level?
its quite possible its just that
Old 08-23-2005, 09:14 AM
cute little bastard
SkoundrelUSA's Avatar
Brake fluid = low
Old 08-23-2005, 11:16 AM
DaveSi677's Avatar
Default Re: Brake light comes on when I take a turn? (SkoundrelUSA)
ok now can break fluid just evaporate? because I know I dont have any leaks. I will check after on my way home and go buy some break fluid. Btw what brand should I get?
Dave
Old 08-23-2005, 11:41 AM
FalkenSiR's Avatar
Just don't cheap out on stuff like that. Don't get the cheapest, and don't buy the most expensive if you don't have the money. MC's can leak internally. Happened to my EF all the time. Ran low on fluid every couple weeks untill I replaced the MC itself.
Old 08-23-2005, 12:56 PM
tpr
tpr's Avatar
As the pads wear the fluid is displaced to the wheel cylinders. The fluid can get quite low in the master cylinder just before the pads wearout completely. If you do not have an obvious leak this is most likely the cause. The only other possibility is that brake fluid is leaking out the back of the master cylinder into the brake booster. this is hard to detect but if it has happened the booster must be replaced along with the master cylinder.
Old 08-23-2005, 02:03 PM
ballin
Chong's Avatar
Default Re: Brake light comes on when I take a turn? (tpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpr &raquo;</TD></TR><TR><TD CLASS="quote">As the pads wear the fluid is displaced to the wheel cylinders. The fluid can get quite low in the master cylinder just before the pads wearout completely. If you do not have an obvious leak this is most likely the cause. The only other possibility is that brake fluid is leaking out the back of the master cylinder into the brake booster. this is hard to detect but if it has happened the booster must be replaced along with the master cylinder.</TD></TR></TABLE>
Yea, If your pads are going, ur fluid level will fall until u get new pads.
PeakBoostSi
Honda S2000
08-26-2009 10:40 PM
stevew84
06-24-2008 06:14 AM
jjr_99prelude
08-31-2007 09:23 PM
businessmanph
02-09-2006 07:32 PM
Sam268
07-30-2003 11:01 AM
Quick Reply: Brake light comes on when I take a turn?
