Air condition making whistling noise
Every now and then my AC will make a wierd noise like a whistling sound when its running. The AC still blows cold though. Lately, the noise has been getting louder and longer. Does anyone know what might cause this and how would I fix it? Thanks for the help.
Re: Air condition making whistling noise (flood)
I've sat around and pinpointed the noise coming from the glovebox area. So if the compressor is located near that area, then "Yes".
Mr. Indecisive
Re: Air condition making whistling noise (9civic5)
Its the blower wich is located under the glove box. The fan blades are plasic and tent to rub and even melt at times, it happened to me on my road trip to virginia. However it shouldnt do this only for the ac but also if you just have the fan on.
Re: Air condition making whistling noise (EJ8VTEC)
LEAVES IN THE BLOWER MOTOR!! You will need a 8mm socket to take out the 3 bolts and clean out the leaves
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9civic5 »</TD></TR><TR><TD CLASS="quote">I've sat around and pinpointed the noise coming from the glovebox area. So if the compressor is located near that area, then "Yes". </TD></TR></TABLE>
Well at least its not the compressor/pulley. The noise is mostly harmless I would suspect but I bet its annoying. I would agree with above poster that its most likely the fan.
guymontag
02-20-2016 01:38 AM
jrock1234
06-04-2012 12:26 PM
