Speedometer problems...
Old Aug 23, 2005 | 01:08 PM
philly91crx's Avatar
Default Speedometer problems...
Im having problems with my speedometer and odometer. Niether of them work but the fuel and temp gauges both work... ive checked the connectors on the back of the cluster and they seem to be fine. Other then a bad cluster what other things could possibly be causing this...possibly the vss?? Any help would be greatly appreciated.
edit: The car is a 94 civic cx hatch
Old Aug 23, 2005 | 01:51 PM
95dxhatch's Avatar
vss is bad. should be able to pick up a used one from someone for 10-20 bucks.... i did. dealer will want i think like 125 for a new one. just replace
Old Aug 23, 2005 | 01:56 PM
ekcivic9's Avatar
check the fuses before that.
i thought it was my vss, or my fuses... but it just turned out the speedo broke. (going too fast can cause that to happen)
Old Aug 26, 2005 | 09:37 AM
Default Re: Speedometer problems... (philly91crx)
Ok well im still having the problems...i replaced the cluster and the vss still no luck...any additional help would be appreciated
Old Aug 26, 2005 | 10:13 AM
allanonjj's Avatar
When u replaced the vss, Did you MAKE SURE that it came out of a d series motor? The reason why I ask is bc I had the same problem, went to junkyard, they gave me an Acurea Legend vss. It looks Very similar to the b series and d series (they are the same I think) but it doesnt work the same. Make sure of that if your not already, Then check fuses. I would also check the wiring with a multimeter.
Good luck 2 ya
Old Aug 29, 2005 | 07:55 PM
Glai1628's Avatar
Default Re: Speedometer problems... (allanonjj)
how do you check the wiring with multimeter like what do i look for? and what fuse would it be? ive change the speedo 3 times. i even changed the harness the last time i change the speedo.
also how do you take the cluster apart?
blinger
11
Mar 26, 2024 08:08 PM
Outrun
Nov 25, 2013 01:24 AM
floridaEg8ferio
Jul 12, 2011 06:09 PM
confusion
May 13, 2007 02:22 AM
spaceman00
May 2, 2007 07:27 AM
