is not the main relay
hey guys
when I turn the key to ACCII. nothing happens, I try to put my windows up. but they dont move.
the fuel pump doesn't com on.
"I think" it's the main relay because....
when i turn my car on it turns right back off. ,
But i been wondering what does the main relay have to do whit my windows not getting power?
my quetion is what does the main relay have to do whit my windows?
Re: is not the main relay (luckygispol1)
it has nothing to do with your windows. they key has to be in the on position for the windows to work as in the position the key would be when the car is running.
Re: is not the main relay (e jay one)
Is ACC the first or 2nd click? The first click is only good to listen to the radio and even then thats bad because it drains the batt.
The 2nd click is when everything comes on. Then another turn starts the car.
Re: is not the main relay (Luserkid)
When i turn the key to position "II" the Check Engine Light, Oil light and Battery light, does not turn on
what does this means? when i turn the key to position III the car turns on but as soon as i let go the key the car truns back off.
Re: is not the main relay (hatchi)
so if im reading this right your saying you can turn the car on buy turning the key to the III, but when you let the key go and it falls back to the II where it stays when your cars turned on and running the car turns off. I had that problem in my old car and i had to replace the ignition switch. The part the actually key goes into.
Keith
Keith
fenix4o9
03-26-2010 05:41 PM
H0nda1
14
09-09-2004 09:20 AM
kolumbus4
07-08-2004 12:45 PM
