ive had it with no search, can i put Legend GS calipers on my civic?
does anyone know the answer to this, or may be able to point me to a thread that addresses this? i'm crippled without the search function.
THe calipers i'm referring to are the 94-95 legend GS 2 piston calipers, and I have a 96 civic EX. Does this swap require custom adapter brackets?
Thanks!
Thanks!
Re: ive had it with no search, can i put Legend GS calipers on my civic? (s1ngle)
bumpitty, I think i've found that they will fit on my caliper brackets, but will they fit with the stock rotor size? (civic EX same as civic Si same as all integra) I think 10.4"
They are wider apart (28mm) compared to Integra/Civic which are 23mm, so your caliper pistons will eventually extend all the way out. You can get some 23mm brackets and use those with the GS calipers and that will take care of the width issue, but then you'll still need to get 11" rotors for sure.
Re: ive had it with no search, can i put Legend GS calipers on my civic? (DjGuamstyles)
Look in my signature.
I made a thread about this brake upgrade and there is some good info posted there
Re: ive had it with no search, can i put Legend GS calipers on my civic? (Mr.RHTuner)
check that thread out, i made a post there that maybe you guys could help me with... basically the only thing i'm concerned about now is getting the rotor/caliper spacing right (rotor centered int he caliper...)
hondapwr
09-13-2006 03:36 AM
