Shifter linkage
Shifter linkage
I was wondering is there is any way of eliminating the looseness that develops with time on the shifter. How can I make the shifter as tight or tighter than new. What parts would I need to fix this problem.
Re: Shifter linkage (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">get engery suspension busing for the tranny shift linkage at auto zone for 11-13 bucks.
honda trans bush = part # 16.1101R</TD></TR></TABLE>
Depending on the year Civic you have. The part # for the ES Bushing set mentioned above will not fit all applications. I know b/c the 16.1101R shifter bushings didn't fit into my EH2 shift linkage.
Taken from the ES website: http://energysuspension.com/pages/hon1.html
Civics (1984-87) Manual Transmission Shifter Stabilizer Bushing Set: 16.1101
Civics (1988-00) Manual Transmission Shifter Stabilizer Bushing Set: 16.1102
And here's a how-to on the install:
https://honda-tech.com/zerothread?id=1001924
https://honda-tech.com/zerothread?id=1002429
Re: Shifter linkage (slowcivicSI)
For movement when you press the gas, replace the rubber bushing where the torque rod attaches to the transaxle. For side-to-side looseness, replace the bushings at the shifter.
Any Honda parts counter will have these in stock.
Re: Shifter linkage (cknisley)
Get the Energy Suspension shifter bushings. I had the same problem and the new bushings fixed it 100%. I got it at summitracing.com. Not sure if you can get them at autozone though. Do a search for shifter bushings. There are two articles on how to change them by a member on here.
