obd2a and obd2b distributor?
I am using an obd2b on my friends obd2a car and it wont start. Does anyone know if i have to repin the plug and switch around wires? need a quick response to get his car running thanks
Re: obd2a and obd2b distributor? (ITR.#1446)
I dont think you would have to. I just put a b16a2 (obd2b) motor in my 96. I used a obd2a harness and all the obd2b stuff including the distributor and everything works just fine. Im also using P28 ecu with a jumper harness, but I dont think that will matter.
BUMP for a definet answer.
Re: obd2a and obd2b distributor? (Bgesy)
i believe the only difference is in the obd2b cx and dx. other than that all obd2a and obd2b distributor harnesses should be the same.
Re: obd2a and obd2b distributor? (EE_Chris)
started reading the helms, directions created. just curious, i use the rpm signal for my safc2. losing that from the dizzy, wont my a/f setings get messed up?
1der1
06-14-2019 01:59 AM
Nameless RB26
09-09-2003 02:14 PM
