How 2 convert 96-98 climate control to a 99-00 climate control? PLS.
Umm, I want to know how to convert a 96-98 climate control to a 99-00 climate control. What do i need or what do I need to do? Cause I have this 99-00 climate control just layin around and I heard that you can convert your 96-98 to a 99-00. Please, I've been tryin to find out for like 2 months now. Thanks.
1 Post
Re: How 2 convert 96-98 climate control to a 99-00 climate control? PLS. (dis_jdm_ek9)
Id post a link to my walkthrough but its down at the moment. when it comes back up Ill let you know.
1 Post
http://repo.jackmoves.com/album228 pictures are more indepth than chameleons.
Re: How 2 convert 96-98 climate control to a 99-00 climate control? PLS. (monicle)
If the reason why you want to convert you climate control, is just to have electronic climate and a double din spot for touchscreen etc, then this is the way to do it -without taking out your dash!
Check out post #23
http://www.mp3car.com/vbulleti...nt=23
Check out post #23
1 Post
Re: How 2 convert 96-98 climate control to a 99-00 climate control? PLS. (CivicModz)
too bad that is clearly photoshopped. sure you can make it work but it would take an *** load more time that swapping everything and unless the person is experienced with fabrication it would look terrible. also as for the "remote controll servo" you would need 2 of them 1 for temp and 1 for vents, also what sort of "extra functions" do you think it will get you?
oh yeah forgot about the recirculate/fresh vent flap. Thats on a seperate cable.
Modified by monicle at 9:09 AM 9/19/2005
Modified by monicle at 9:10 AM 9/19/2005
1 Post
Re: How 2 convert 96-98 climate control to a 99-00 climate control? PLS. (chameleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon »</TD></TR><TR><TD CLASS="quote">good job, it really is more detailed! </TD></TR></TABLE>
I gave credit where credit is due though. You laid the path for it i just cleaned up the trail a bit heh.
Yep i know it is photoshopped, as stated in the post. As for the sevo only one is needed for the heat/cold, the vent locations do not require servos as they are already in the dash. The climate just controls the servos (no additional ones are required). Oh and yes, 1 more servo is needed for the recirculate/fresh vent flap, but this has been ommited for a simple plug and play solution.
In relation to the extra features it not much, but might be handy.
- Has 6 fan speeds instead of 4
- You can select 13 individual heat/cool settings (instead of using slider)
- When you press the special demister button - the windsreen vent is selected, then the A/C is also switched on.... 40 seconds later the unit returns to it previous state. This is handy for 1 button demister control.
- The rear demister is also controlled by the unit
- Works with 92 up civics, and accords
- Handy small LCD display insert replaces the rear demister button (for a visual representation of what vent is selectected fan settings. etc) - the rear demister button not needed as it is controlled by the unit.
Yes you would have to do some fabricating, but you would have to do it anyway with you 99-00 dash if you wanted a perfectly stock look.
zess
11-03-2010 07:59 AM
JDM CERTiFiED
02-16-2009 12:09 AM
MonkeyPuzzle
11-18-2006 10:49 AM
