97 Civic DX, to EX manifold conversion!
Ok, soI got a 97 Civic DX, the damn manifold is no good so I want to go with an EX manifold. I got the cat back from a 99-00 Si, it has the o2 sensor on the cat. Who has done this and what do you need to do to extend the wire for the second o2 sensor?
Location: Where the shooting range is on the streets of LA, CA.
Re: 97 Civic DX, to EX manifold conversion! (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Ok, soI got a 97 Civic DX, the damn manifold is no good so I want to go with an EX manifold. I got the cat back from a 99-00 Si, it has the o2 sensor on the cat. Who has done this and what do you need to do to extend the wire for the second o2 sensor? </TD></TR></TABLE>
man i jus did the same thing last week... anysways just extend the wires from the si cat... get the same four colors of wire from like home depot or auto zone etc.... you can even use the same color wire just remember where they go if you want.. cut the wires on the sensor from the cat in the middle.. make sure you have enough wire on the sensor so you can wire it back up after you extended the plug wires... after the wiring is done on the plug, wire it back up to the wires left on the sensor... then plug it to one of the 02 sensor sockets... make sure socket is for the 02 cat sensor. then repeat these steps for the sensor on the ex exhaust manifold... conprenday mi amigo? (do u understand?) sensor on the ex header should be right before it hits the cat ok... good
Re: 97 Civic DX, to EX manifold conversion! (bluebird)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebird »</TD></TR><TR><TD CLASS="quote">You can get an extension made for you 02 sensor plug so you can plug in the primary 02...
Boy, that easy huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen mj5 »</TD></TR><TR><TD CLASS="quote">
man i jus did the same thing last week... anysways just extend the wires from the si cat... get the same four colors of wire from like home depot or auto zone etc.... you can even use the same color wire just remember where they go if you want.. cut the wires on the sensor from the cat in the middle.. make sure you have enough wire on the sensor so you can wire it back up after you extended the plug wires... after the wiring is done on the plug, wire it back up to the wires left on the sensor... then plug it to one of the 02 sensor sockets... make sure socket is for the 02 cat sensor. then repeat these steps for the sensor on the ex exhaust manifold... conprenday mi amigo? (do u understand?) sensor on the ex header should be right before it hits the cat ok... good </TD></TR></TABLE>
Sounds too easy! Oh and it's spelled "comprende". I guess I will tackle this job once I get my hands on an EX exhaust manifold and downpipe, thanks!
Boy, that easy huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebird »</TD></TR><TR><TD CLASS="quote">Call George @ South Gate auto electric 323-564-5570 he has them pre-made</TD></TR></TABLE>
LOL, you know George? I met him once but I know his brother Alex pretty good.
tranmicro
08-03-2006 08:41 PM
CeoStatus0
07-25-2003 04:58 AM
