91integra rear disks?
Re: 91integra rear disks? (datnigabluberry)
Yes and search
They bolt on directly. Then you need a 40/40 prop valve from the integra with rear disc and NO abs. Get the 15/16" MC and it will bolt onto your existing Brake Booster.
Re: 91integra rear disks? (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">Yes and search
They bolt on directly. Then you need a 40/40 prop valve from the integra with rear disc and NO abs. Get the 15/16" MC and it will bolt onto your existing Brake Booster. </TD></TR></TABLE>
Yup You'll want the 94-97 Integra RS prop valve... (RS' don't have ABS) and the 15/16" MC is from the 1991 Civic EX 4door, I got mine from NAPA, and got the right one on the first try... it was only like $70
Re: 91integra rear disks? (Dr. ******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. ****** »</TD></TR><TR><TD CLASS="quote"> You'll want the 94-97 Integra RS prop valve... </TD></TR></TABLE>
yea a 90-93 integra 40/40 prop valve will still work the same
ok kewl sry bout the search had to run to work and wanted to know if they fit cause if not i was gonna junk the set up thanks guys
sinyce
08-02-2016 10:48 AM
