guys i need ure help only u guys can help!
hey guys how u doing i just bought acar('95 honda hatchback with aswaped engine gsr)
the guy told me that all i need to do is change the right axle.
i took it for adrive and if u drive slow it's all good as soon as u hit the gas u feel the whole front of the car shaking. and it starts from the front right side.
i went to the shop changed the right axle and it stil does the same thing.
u can drive it in 5th gear but just dont hit the gas all the way it will drive smooth.
by the way the car is really lowered i dont know if that has something to do with it.
but guys if u can help me out on this one i'd appriciate it alot really.
thanks alot in advance.
my email is jhon300@yahoo .com plz help me out
you kinda have to be a lil more in depth with the syptom that your having.. by shaking i guess you mean you feel a vibration or is the steering wheel shaking? my guess from what you said would either lead towards motor mounts, or even suspension.. i would take a look under the car to see if anything is loose, try prying on the ball joints to see if they have excessive play.. another test is to put the car on jack stands in front, put your hands at 3 and 9 oclock on the rim and try shaking it and then do it at 6 and 12 and see if you feel any play or hear any noises.. get back to us
Re: guys i need ure help only u guys can help! (ronsxi)
broken belt in tire-wheel out of balance-bad strut-motor mount-ballloint. could be anything, sorry, good luck.
