taking off crank pulley bolt
OK i'm just curious about this technique.
I'm going change my buddies timing belt for him.
he's got a 00dx
what I usually do on my car(92eg) is put it in 5th, lock the brakes,
then pop the bolt off with a breaker.
So what i'm wondering, is do you guys think this technique is safe?
I'm wondering if it puts stress on the tranny or anything like that?
Seeing as it's not my car i'm working on I don't want to eff anything up.
he's got a 00dx
Re: taking off crank pulley bolt (Tad)
That's the same way I did it on my 99 hatch. Worked pretty good. Plus you can do it with one person. Much safer IMO than wedging a screwdriver in the flywheel.
O.G. triple O.G.
Re: taking off crank pulley bolt (elpiar)
I have used a tool similar to this one. The only drawback is that you have to have a lot of room to hold the breaker bars...unless the car is on a lift.
Re: taking off crank pulley bolt (MormonBoy)
that method should work fine unless its an east coast car....
otherwise u can borrow the one i got (maybe not this weekend)
oh yeah, look what JDMlyfestyle did for his... (image will be taken down at request)
1st gear would be a better gear to put it in since 5th would spin the easiest but n e ways i always use the screw driver idea in flywheel and always using air tools and break bars
mhernandez
16
07-10-2012 07:53 PM
socialistic
31
06-26-2011 12:54 PM
