i know you hondata guys can answer this....
well i was wondering if you can run hondata s200 w/ boost option with a motor that is using itb's allmotor?
also can this hondata boost option be disabled?
my setup is as follows:
LS/VTEC
ctr pistons
cometic thick head gasket
arp rod/ main/ head bolts
gsr h2o pump
gsr pan
gsr girdle
itr cams
jg cam gears
954 cc itb's
440 cc blue tops
MSD Sport ignition
denso plugs
ngk plug wires
aem fpr
walbro 255 lph fuel pump
dc 4-1 header
CTR n1 crank pulley
my crx is setup for obd 1 and im using an obd 1 ecu.
LS/VTEC
ctr pistons
gsr h2o pump
gsr pan
gsr girdle
itr cams
jg cam gears
954 cc itb's
440 cc blue tops
MSD Sport ignition
denso plugs
ngk plug wires
aem fpr
dc 4-1 header
CTR n1 crank pulley
soslodelsol
05-02-2006 10:37 PM
92slowvic
08-20-2004 05:41 AM
