having bad vibration when braking.. ideas??
hi guys car is a 95 hatch with drum rear brakes.
they shook real bad when braking over 40mph
i redid them on both sides with rebuild kit aswell.
pads were not worn all the way down.
after install problem still persists.
what else could this be?
195,000 on car. bushings look a little worn back there.. like the trailing arm.
would that be a culprit?
1 Post
it is the rear that is shaking? usually the front rotors warp and causes the car to shake. if you have worn bushings, that can cause shake... but not as likely as a warped front rotor. pull the rotors in the front and check them.
Re: having bad vibration when braking.. ideas?? (bushfreakz)
I had the same problem with my brakes I just adjusted them with the little adjuster they have when u take the drum off it looks like a gear do u no what im talking bout ????
so is the shaking coming from the front or the back because if it is from the front adjusting the rear brakes wont help for ****
Re: (bushfreakz)
its a spinning gear you just adjust it little by little first put the car in the air take all rear lug nuts loose spin the tire let go and it should only do bout half a turn with out you touching it if does more or less they need to be adjusted
hope it help if you need further explanation just I.M. me
easy check before pulling wheels off...get up to speed and put it in neutral, pull up your parking brake. if you get the same vibration it's your rear brakes.
SlowB16
09-07-2013 12:41 PM
