Having trouble with coilover installation
Old 05-03-2006, 03:36 PM
Chris Benoit's Avatar
Default Having trouble with coilover installation
Hey, So I was installing my f2 coilovers today and the first three went on without giving me any problems.
But on the final one (rear drivers side) I can not get the 14mm bolt in the LCA off. I have soaked in it wd-40, and tried so hard that I bent the socket wrench.
So my question is have you guys ever had a bolt that was on so tight? The others definately took some muscle but this one is kicking my ***.
Any ideas?
Old 05-03-2006, 03:37 PM
graveltravel2's Avatar
airtools.
/thread
Old 05-03-2006, 03:40 PM
Banned
strictly.business's Avatar
Default Re: (graveltravel2)
breaker bar. and thats called a ratchet by the way, not a socket wrench. us quality stuff and it wont bend. forged>cast.
dem0nk1d's Avatar
buy top name tools, even crapsman isn't too bad
Old 05-03-2006, 03:41 PM
keemosaki's Avatar
got a good grip on it eh? use PB buster, soak that bitch in it, then take a torch to it... use a big breaker bar first, then add a steel pole to it to add leverage. If you still cant budge it with jumpin on it (safely) then take it to a shop that has that 200lb+ air tool.
Old 05-03-2006, 03:45 PM
Default Re: (keemosaki)
I think even with a top of the line ratchet (my bad) it's still to tight to budge it. Does any place rent out airtools?
I'm going to borrow a breaker bar if I can but I'd rather just use airtools.
Old 05-03-2006, 03:56 PM
jtchinoy's Avatar
did you try putting a pipe(like the handle of a racing jack) over your ratchet when you were trying to loosen it? Leverage FTW. And how long did the WD40 sit?
Old 05-03-2006, 03:59 PM
Default Re: (jtchinoy)
alright so we switched to a craftsman ratchet with a steel pipe for a breaker bar and it came off no problem. thanks guys.
Old 05-03-2006, 04:55 PM
spoonracer84eg's Avatar
Default Re: (John Cutter)
I had to cut mine off with a damn saw so be happy you managed to get yours off.
Old 05-03-2006, 05:02 PM
zaroooo9's Avatar
when i did mine, both of the bolts on the pass. side rear lca snapped and i drove 2 hours home with them like that. my hatch is from boston, so its hella shitty underneath. it turns out the bolts were completely seized and it took the shop like 6 hours to drill them out.
take it to a shop, or drill them out yourself. they are probably seized.
Old 05-03-2006, 05:26 PM
mtny's Avatar
Default Re: (zaroooo9)
I put on H & R Race springs on my EM1 today and we used airtools. We tried using shitty handtools yesterday and couldn't even get started. Find someone who will let you use an impact wrench and compressor. Life will be alot easier.
Old 05-03-2006, 05:36 PM
john666's Avatar
Default Re: Having trouble with coilover installation (John Cutter)
i use a dewalt impact wrench when i dont have a air compressor/gun
its electric so just plug it in.
my dad got this for me for 20-30 bucks at the swapmeet
i love my ef
04-07-2006 10:05 PM
Understeer
04-01-2005 08:39 PM
cyberneo344ib
05-10-2004 04:28 AM
tegasaurus
08-10-2003 04:34 PM
Adachi
03-03-2003 08:04 PM
Quick Reply: Having trouble with coilover installation
