Wire Harness Help (B18C1 in 92 Dx Bubble)
The GSR in my EG started up fine but it's throwing a few codes. I should have the mess sorted out quickly though. Anyway at the passenger side shock tower one of my plugs isnt connected to anything. I dont see anywhere that I can connect it either. Can someone help me out here. Is this ok? BTW I'm using OBD2 harness, dizzy, etc. But the car is OBD1.
all of the other clips connected. take a look.
passenger side plug? looks like the map sensor plug. you may have it as extra.
make sure u get that knock hooked up
if the motor and ecu and harness is OBD1, IAB is easy - use the evap purge wire and move A20 to A17 on the ECU.
OBD2, a little different move A20 to A17 and find a ground for the 2nd wire.
1 Post
Re: Wire Harness Help (drshottest718)
that extra harness is there and it doesnt go anywhere coz your car dont have it since its obd1. Your tach will not work also and you need to run a wire from distributor to driverside wire and tap it in
Re: (crxcel) need help with making a usdm eg harness work with a jdm b-18 application
maybe you can help me, im doing a jdm b-18 swap on a 95 eg hatch and im basically finished all i need to know is if im using the original harness from the eg and use it for my b-18 what sensors will i have to re-wire in order for it too work and which plugs do i salvage from b-18 harness please help screen name joz_mendoz
Re: (crxcel)
maybe you can help me, im doing a jdm b-18 swap on a 95 eg hatch and im basically finished all i need to know is if im using the original harness from the eg and use it for my b-18 what sensors will i have to re-wire in order for it too work and which plugs do i salvage from b-18 harness please help please e-mail me some info joz_mendoz@yahoo.com
Re: (joz_mendoz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">that extra harness is there and it doesnt go anywhere coz your car dont have it since its obd1. Your tach will not work also and you need to run a wire from distributor to driverside wire and tap it in</TD></TR></TABLE>
your tach should work fine i did the same swap and i just left it unplugged no CELs and tach an perfect...
bmoney
08-13-2006 01:36 PM
quicksilverej6
03-22-2006 05:48 PM
A.E Motoring
11
01-08-2006 09:05 PM
