d-series with lsd
Risky Business
Re: (MiSoJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiSoJDM »</TD></TR><TR><TD CLASS="quote">the d15b tranny came with lsd</TD></TR></TABLE>
Only a select few.
Only a select few.
Re: (viskii420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viskii420 »</TD></TR><TR><TD CLASS="quote">obx lsd is affordable and good product</TD></TR></TABLE>
not from the things ive seen.
buy a real differential. you get what you pay for. my diff costs as much as a replacment transmission but ill never have to worry about it grenading.
Go Tigers!
Re: (Kamin)
the oem jdm is a 1-way viscious coupling lsd. correct me if i'm wrong.
get a quaife. its worth it.
And while you're at it, vote yes for the tranny forum.
correct me if i'm wrong..
the jdm d-series eg hatch and sedans that came with factory four wheel disc brakes came with LSD tranny.. like the jdm eg hatch with a ZC motor and other d15b.. these tranny are quite rare but not here in my country..
in fact i'm using one for my d-series motor.. it's code is S20..
Re: (sohc1200cc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">the oem jdm is a 1-way viscious coupling lsd. correct me if i'm wrong.
And while you're at it, vote yes for the tranny forum.</TD></TR></TABLE>
man loves his tranny's
no the tranny code is the same the only way to know is to look through the axle shaft holes, if you see straight through its LSD, if theres a crosspin its open diff.
Re: (sohc1200cc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc1200cc »</TD></TR><TR><TD CLASS="quote">in fact i'm using one for my d-series motor.. it's code is S20..</TD></TR></TABLE>
Aren't all 92-95 D series trannies coded S20xxxxx?
mine is s40 and i;m pretty setisfied w. it.. but havin an lsd on it would do much better... so im wondering since u pointed out that auto tranys got lsd can i swap from there and if i do would it hold to 300whp or i should consider an aftermarket one?
yeah but they dont give u waranty on it.. my plan is to swap it before i ship to gear speed and let them inspected.. since they give u 2 yearts waranty on an oem replacment
Re: (NopSpawn)
Go with the Quaife, had one in last years tranny with DSS stage 3 axles. Car only ran high 11's but that was because of other issues. The Quaife was perfect.
This years B serise tranny has a Quaife in it.
If your going to do it, do it right.
Re: (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">no the tranny code is the same the only way to know is to look through the axle shaft holes, if you see straight through its LSD, if theres a crosspin its open diff.</TD></TR></TABLE>
Totally agree w/ this. I have one in my mini-me and it's all good
be professional
Re: (viskii420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viskii420 »</TD></TR><TR><TD CLASS="quote">yeah but they dont give u waranty on it.. my plan is to swap it before i ship to gear speed and let them inspected.. since they give u 2 yearts waranty on an oem replacment</TD></TR></TABLE>
All Quaife ATB differentials have a lifetime warranty.
http://www.quaifeamerica.com/d...y.htm
You'll probably never need it anyway, because they are next to impossible to break.
