quick question: tach problem
I just swapped in a d15b in my eg hatch and now with the car idling, the tach shows 0 rpm. Now i built this car from a shell, so i don't know the history of the gauge cluster (don't know if this was a previous problem). Now when I'm driving the tach is working, although probably not accurate. So I think its safe to say this isn't an electrical problem....right? Is there a way to adjust the tach? Any help would be greatly appreciated.
Re: quick question: tach problem (e-Roc)
Hook anther tack up to see if it is in fact your cluster or not, otherwise you can hook up a scanner to see where your tach should read, pull off the needle and push it back on where it should be.
Check my sig I think I have a thread in there giving you directions how to do this, the one titled on how to reset your speedo or something like that.
Re: quick question: tach problem (nocturnaldragon)
ok I just noticed I took it out, so you'll have to search for threads I created in the past.
Here you go,
https://honda-tech.com/zerothread?id=851492
Here you go,
