b16 turbo question
b16 turbo question
ok got a jgenginedynamics stage 2 block with a gen 3 cyl head, 62-1 turbonetics turbo,770cc injectors, 30x12x3 intercooler. has anyone ever used methanoel injection on a b series car? what was the outcome? good, bad?thx in advance
1 Post
you will find a lot of meth and water injected guys on evo and wrx forums. meth injection is a good thing and IF installed and tuned properly, the car can make A LOT of power. There are guys in WRXs that pick up about 100 hp just from going to meth injection and changing the tune. With meth injection, your cylinder temps drop and detonation is less of an issue. You can run more boost, more timing... more power.
Re: b16 turbo question (OuttaGas)
is the car already tuned to full power?
or your just contemplating doint the injection to top off your list of parts?
run the car, tune it, then if you realy need the injection to drop temps down do so if not dont throw in another possible mishap fo rthe car!
im sure you can make good power with your setup without haveing to go with injection!
its just toppin off the list. wanting to get the full potential out of this go around. plan on tuning it at 20lbs on 93 octane. thats why the meth idea also came into play. so we could keep it on pump gas.
B16Civic93
05-17-2005 08:13 PM
